- Replies 10
- Views 3k
Mopar1973Man 4 posts
Doubletrouble 3 posts
That Guy 3 posts
Ok... Pull the gear case front off being I want to check the bolt along the block edge to tighten. Still can't see all them but the top on for the KDP pin. But... I might of dove in too q
Actually I think I got it. Between the front cover might of been weeping around the edge. Then the vacuum pump bolts were totally loose on the bottom. The only bad thing that happened I d
A few drops of the uv leak detect die in the oil will tell you all kinds of things. It's the only way we found leaks on the the equipment once they get all grimy with a half inch layer of sludge built
Could I ask a huge favor from someone. I would like a picture of the inside of the gear case and where all the bolts are without the cam and pump gear in the way. My oil leak is on the rear side of the gear case and running down to the corner of the pan and blowing back. I'm looking at options to tighten all the bolts and see though. Or loosening all the bolts and separate a little and get a small bead of silicone behind the edge. Either way it leaking engine oil pretty good in 15 miles its got oil splattered all the way to the transfer case.
