Installing air springs, hose question.
I ordered a Firestone air spring kit for my truck, installation appears pretty straight forward.  I had a question about the air hose routing though.  I got the optional "T" fitting as I mostly need the kit for leveling while pulling a trailer.  I want to mount the schrader valve near my tool box on the passenger side of the truck close to my compressor for quick easy filling.  Will it matter that the air lines from the bags to the "T" are different lengths or do I need to have them equal with a central meeting point?
  • Replies 23
  • Views 6.8k
  • Personally, I would not join the two rear airbags together with a T fitting.  If they are joined, then truck lean will be accelerated while traveling through a curve because air will be transferred fr
  • Royal Squire
    Royal Squire
    Interesting license plate
  • Dieselfuture
    Dieselfuture
    Works good just wish the gauge was more accurate about 3-4 psi off digital and scale a 100 instead of 200 for better accuracy. Other than that I like it. Had to run 3 lines in the cab on my set up, on
38 minutes ago, Dieselfuture said:
:poke:
ouch!!!!
Ooh, I can reply again, tried awhile back but nothing would happen.  I got them installed, came with this nifty little bracket that makes attaching the valves to a square tube real easy so I attached them to my headache rack near my compressor.  I had one leaker which was my fault, neglected to fully insert the line in one of the valves.
