05 removing negative battery cable problem.
Hey everyone.I need to clean corrosion on the battery terminals on my 05. I'm having problem w/ finding the right socket/wrench size that fits that nut. It's small w/ the small bolt which looks to me to be 1/8". Anyone know the size of that nut? I can fit a 11/32 over it but it won't catch. 5/16 and 8mm is too small. It's got so much crud that I can't really tell if it's a nut at all. Really appreciate the help.Thanks,Eugene
  • Replies 25
  • Views 7.7k
Funny part is if you take care of it in the first place you'll never have to worry about cleaning, removal problems, rusting, corrosion problems, etc...
That nut should be a 10mm. I just did a battery swap and they look like they did in 04 when the truck was sold.
no..this post is helpful to folks who needs help on this subject...so no it is not done unless mopar closes it...and keep em clean..that is :smart:
I really didn't think we get 2 pages out of this and I'm glad we got good ways on how to clean the corrosion off. I've always used the electric glop my friend gives me. I don't know what's it's called but it works really well. The problem is the PO didn't really take care of the truck. I wouldn't have let it get that way in the first place. Keep them clean and they'll work better.Eugene
My saving for the truck is going to take a hit... I started the backhoe yesterday... jumped it off the CTD. It started well, considering how long it had been sitting under that tarp. Some of the hydraulics are stiff... they work but the controls don't return immediately when you let go. SURPRISE!!
The batteries have been junk for some time... If it stops (stalls or is shut off) somewhere I can't get to with the truck, it won't restart. So I'm going to bite the bullet & put batteries in it. $228 for the pair from NAPA... in stock. I've got them freed up but I can't lift them out of the hole under the deck... gotta get nephew in to help.
Wifee has got in-laws to cut some trees down & a piece of heavy equipment would be very handy. We have managed to take down some big ones (3 leaning over the barn & the latest leaning toward the house). How it was done: Ropes in direction of fall. Carefully notched the direction of fall. Made the cut & used wedges to push tree over. Big tree over barn, we had the backhoe on one of the ropes. Should have done that yesterday.
Posted Image
In fact this picture was taken BEFORE those trees were removed... seen over the "hoe".
Batteries are marked "97"... treated felt washers on all the terminals. NO corrosion, came right off. It is interesting that the felt washers LOOK dirty but nothing more but are mush when I tried to take them off. I bought new ones for the new batteries I brought home today.
