Low voltage to fuel relay
- Replies 11
- Views 2.7k
W-T 3 posts
LorenS 3 posts
Mopar1973Man 2 posts
Camocoaltrain 1 post
I too was wondering where @Camocoaltrain was in the fray of this topic. Also, @Dieselfuture thank you for the acknowledgement...my dismal record of activity due to circumstances will impro
Great to see you hanging around here once in awhile, hope things are going good for you. Thanks for your knowledge and contribution to keep our gremlins under control.
Camocoaltrain, Please show the method and the device of "how you are measuring" this DC voltage. Allow us to see your analytical procedure...photos of your connections to your DC mul
I have a 2000 3500 5 speed. New built engine. Currently getting about 9 volts to fuel relay. Truck started and ran upon engine install but oil change place arced alternator on oil filter. Injector pump was fried, so I replaced. Traced back to computer. Sent off twice and got same result. Installed computer on another truck, same result, have to jump pins for relay to start engine. Sent off to Auto computer specialist this time, same result. Fass comes on and works fine but injector pump won't create pressure while this relay is getting low voltage. Please help. I have used this site for testing wires and can only come up with computer failure but after repairing 3 times now with two companies, I'm at a loss.
