Any info on the HY35?
- Replies 16
- Views 4.2k
Mopar1973Man 6 posts
dripley 3 posts
craneop 3 posts
Zukifreek 1 post
I have searched and found nothing on the Hy35 turbo. I had my truck at a friends shop last week for an alignment, while test driving I asked him to run with the scanner on, he first ran with the edge comp on and then with it off. the boost pressure at idle was reading 10-11 psi in both scenarios then went up to 28-29 psi in both scenarios. I was wondering if this is normal or if there is any way to test the actuator on these turbos. the line b/t the housing and the actuator is steel, not rubber. I have had the rod b/t the actuator and the wastegate off and the wastegate moved freely. Thanks in advance, Luke
