2 Different Boost Readings - Bad MAP Sensor?
- Replies 20
- Views 7.2k
Mopar1973Man 8 posts
MikeH 5 posts
Octafish 4 posts
dripley 2 posts
Be best to have a tuner and gain back the boost fooler. Like the 2006 I've got any time it has any engine code the boost is limited to barely 20 PSI which the EGTs are much higher. When all codes clea
Cool. At least you heading forward again.
Some time you need to rely on live data. Then remove any add on like tuners to see if the tuner is at fault, which sometimes happens. Then at least you know what is at fault sensor, boost fooler or wi
My Stewart Warner pillar gauge and I-Quad aren't reading boost the same.
When I'm on the throttle, the pillar gauge says 35+ and Quad says 5-6.
At cruise, mech says 4-5, Quad says 0
No doubt the mechanical gauge is right and Quad is wrong.
I hardly use the Quad gauge on my phone so I don't know how long there's been a difference.
No codes. Map sensor is clean - no soot.
Is the Quad reading directly from the MAP sensor or thru the ECM?
Can a MAP sensor be sick and not throw a code?
