- Replies 7
- Views 2.2k
Mopar1973Man 3 posts
Dieselfuture 1 post
ddmk6 1 post
Great work! 1 post
Popular Days
I didn't use anything this time, set it in the groove, used the above mentioned sleeve retainer/activator and used a big brass drift/BFH and smacked it a couple times. See how it does. Yea, I a
Be careful. If you use too much of that product it can and will blow the pump or the hoses. I've seen it done on a older Ford pickup and the thickness of the product can increase pressure sharply and
I know this might not be a leak most encounter, but when I rebuilt my engine, I used a little RTV on the o ring for the cam plug in the back of the block, did good for 120K or so, then I added Lucas oil supplement, WOW at start up had near 100psi oil pressure, started leaking like a sieve, any way this time no RTV on O ring but I did use Permatex sleeve retainer # 64000/ and the Surface prep/activator # 24163. Hoping it will last me more than 16 mo's.
