Nearly all miles have been highway miles. On 2 separate occasions, P0306 code appeared, and then cleared on its own. 3rd time it appeared, all plugs and #6 COP were replaced. Code returned shortly afterwards. Went back in and replaced #6 Injector. P0306 code ever present. P0306 is only code that has ever been presented. Any suggestions would be appreciated. Thanks
A torque wrench is needed when working on aluminum alloy engines. Over tightening will pull the threads out.
There are 2 ways to find a vacuum leak at the intake manifold/gasket.
Hello,
