Yet Another Fog Light Thread
- Replies 32
- Views 5.7k
sleezy 13 posts
dripley 6 posts
Silverwolf2691 6 posts
Mopar1973Man 3 posts
Yes, now that I've seen your setup I think that's right. Switch and relay are on their way, and I just ordered the connectors for the back of the bulbs. No idea what the "truck side" connector might b
Albert freaking Einstiens!!!
Bulb socket is empty because that switch isn't a fog light switch. The rotary switch pulls out for fog lights, says pull with the fog symbol on it, and you can see the fog light symbol that lights up.
I know this has been discussed at length, and believe me, I've been through (I think) all the threads on this on multiple sites and just can't seem to get a bead on exactly what's going on with the non-factory-foglight trucks' wiring. I'm in the middle of a pretty extensive interior rehab and figured it's time to finally dive in.
I have a 2001 (manual trans, I saw one guy claim that matters?) without factory fogs. I've picked up factory housings/brackets, bumper inserts, and a fog light headlight switch. I do have the harness down by the front bumper. I pulled the headlight switch today, and it looks like the harness runs to the dash too. It also looks like it's plugged into the switch?? Maybe it was just easier to have one housing for both switch types? What's funny is the bulb socket (that I assume is the fog light indicator) is empty.
Can anyone confirm whether that two wire plug is in fact for the fog lights? I think it must be because the back of my old switch is identical to the back of my new switch with the fog light pull out. I'm hoping that means I can just plug in a fuse and probably a relay and get power to the harness at the bumper?
Just so it's out there: yes I know I can install a toggle switch. I already have lots of toggle switches throughout the cab. What I'm going for here is factory fog lights with the factory switch.
