- Replies 9
- Views 1.5k
Mopar1973Man 4 posts
JAG1 3 posts
IBMobile 2 posts
Popular Days
They cost more because you get an extra drum stick. https://www.youtube.com/watch?v=i3kpYiWdVWY
Only find those in North Carolina... @dripley most likely has a private farm out there somewhere... Most likely takes them out in the "Chicken Caddie" for rides at night. Yeah its been
Video is a must watch... Still in all all this talk of Global Warming or Climate change is just a democRATS scare.
I'm starting to hear on the local radio that McCall ID is calling for water conservation. Giving guides on watering at night, using hose timers, etc. For myself its been a bad year just trying to keep water going. The loggers that log out behind us happened to damage two pots in the water line. Between the neighbor and myself we managed to get water going. Shortly after that fix I ended up having a filter problem down hill at my place. Mud and needles washed down and plugged the sediment filter. Clean the cup out and filter and now noticed the sand wore the bottom of the filter cup out. so thin it was leaking water out at 120 PSI through small cracks in the cup. I happen to have a tube of epoxy and started mixing up batches of epoxy filling the wore groove in the cup. 15 minute set up time. Managed to just get water back up. Now my yard is super dry. I lost all the cherries (fruit not the trees) being extreme heat and lack of water. Now got 2 good hoses and going to head to town soon and pick up hose mending supplies and repair my hoses and get the place watered.
Weather wise its been floating right at 100 degrees here day in and day out. We maxed out at 108*F here for one day. I've seen over 118*F in Riggins, ID and Lucile ID just out working job. Rivers are all down on flow and even rafting companies are wondering how much lower the river might get. Here is the river acros the road from me. The triangles are the average flow.
