High IAT, Low Power, Low Boost
- Replies 9
- Views 2.7k
BRI7070 4 posts
Mopar1973Man 2 posts
Me78569 2 posts
Silverwolf2691 1 post
Hello All,
its time for another problem. I have an 01 2500 (DFI 7X009 injectors, DTT Trans with 89% converter, 3.55 gears, 265/70/17 Tires) and I recently removed my stock exhaust manifold and Hy35/9 turbo and AFE air filter and replaced it with an Insta-Spool Super 9 turbo, ATS 3 piece exhaust manifold and a Power Driven Diesel Dust Bowl air filter. After installing those items I took it for a test drive and all was good. Spooling was nice and had about 38 psi max boost and EGT's were higher than I thought they should be, 950-1000F at 65 MPH on flat ground no load. I called Power Driven Diesel and asked about the boost numbers and EGT's and they asked me to increase the W/G spring tension by 3 turns. This netted me 45 PSI and 900F. Over the next few days I have noticed excess smoke, rising EGT's, rising IAT's lowering boost numbers. When Pulling my 5th wheel, about 8,000 lbs, on flat ground at 65 mph I had 1250F and 10 PSI. At this point I was not monitoring IAT's. Well that did not seem right so I called Power Driven Diesel again and they asked me to put my AFE air filter back on. I did and no change. I started trouble shooting and noticed with my Torque App my Throttle position would only read 68% when I was at WOT.
After some research I found others were reading the same so I borrowed my buddy's Scan-tool and the throttle %'s and it read 0 and Idle and 100% at WOT. I did a cylinder deactivation and looked at the load values for each cylinder. with all 6 running my load was 15% and each time I dropped a cylinder it would read 18-19%. I feel that it is consistent so that is good. This is when I started monitoring IAT's. when pulling my 5th wheel I would see 155F on flat ground at 65 mph I had 1250F and 10 PSI. I read that if my POP pressure was low it could cause the symptoms that I was seeing so I pulled my injectors and took them to Valley Fuel injection and they tested at 270-280 range. I have them adjusted to 300 and new coppers and seals. when I installed the injectors I adjusted my valves and all were with in 0.005" of spec.
With the valves adjusted and the injectors back in, she idled smoother, ran quieter and revved a bit faster. On a test drive I noticed lower power IAT's 155-160F throttle position was higher to maintain 65 mph and more smoke, 1300 EGT 10 PSI.
Tonight I replaced my IAT sensor with a Napa one and no change in IAT readings. I did get a low boost P0237 and P0113 IAT Sensor 1 circuit high. On this test I could not get over 55 mph and max boost was 28 psi and EGT's 1400F.
Things are going down hill fast and I need HELP.
Any Ideas? Sorry for the long post but trying to give you all the info I can.
TIA.
