- Replies 12
- Views 3k
Silverwolf2691 5 posts
YeaImDylan 3 posts
Mopar1973Man 2 posts
Dieselfuture 2 posts
If you have a CAD axle, which it seems is true, the 4x4 light is triggered by the axle shift fork. The large vacuum switch on the transfer case is for actuating the shift fork only. How th
https://www.jbconversions.com/products/np241/rebuild.php the part is listed under np241c, so I don't know what is different if anything between the dodge and chevy. You would need a wide c
Hey all, thought I'd post this to get some opinions on what to look into replacing or adjusting...
So when I shift my truck into 4Hi, my dash 4wd light comes on but when I go and give it gas and start to drive, my shifter goes back into 2wd. I'm assuming this could be due to a worn transfer case linkage? Mine is currently in the same state as when I bought it from the P/O and its held together pretty janky.. has a zip tie or two on it.. lol the t-case shifter is also pretty damn loose but I do feel it "go" into 4hi in a way.. I also don't believe my front end is engaging. I held my hand on the shifter in 4hi and gave it gas and had a buddy check my tires in the front and they were spinning freely (in a bad traction environment). I'm assuming its due to old and cracked vacuum lines. Need opinions on this too, should I go with a 4x4 posi lok system to get rid of trying to chase down vacuum leaks?
