Brake Light Switch..."DO NOT REINTSALL"
- Replies 38
- Views 28k
MikeH 12 posts
Mopar1973Man 10 posts
Dieselfuture 4 posts
dripley 3 posts
About 150,000 miles ago my brake lights were staying on. I removed the brake light switch and modified it to be reusable. I cannot remember what I did to it, but I know it was simple. I am currentl
It is beyond my ability to comprehend as to why a simple brake light switch would be engineered in such a manner that it could not be reused. i suppose if you removed your brake pedal, you couldn't u
If you look at the design it has a ratchet design to self adjust during install. If you carefully pull the plunger back out you can re-install it again. Yes I've actually figure it out and been able t
I had to rebuild the hydro-boost on my rig for a leaking seal. Found a YouTube page with very good instructions for the repair. They did recommend replacing the brake light switch also as it was a one time use only item. If you didn't replace it your brake lights would stay on all the time. Seems like it loses it's setting once the brake peddle is disengaged. Got a new switch and the install was fairly simple.
Took the old unit apart to see if I could "reset" it. I was expecting a small circuit board of some kind but it was totally mechanical. Not sure I'm seeing what could be out of whack just by removing and replacing the switch on to the same peddle & rig. It's just a plunger with several ears (cams) engaging and disengaging a few micro-switches.
Anyone know for sure if you can reuse these or not?
