- Replies 8
- Views 2.4k
Cae236 4 posts
Mopar1973Man 2 posts
IBMobile 1 post
Haggar 1 post
Having a new issue.. idling truck runs great very slight haze but nothing new.. take off down the road under low throttle it does great.. than between 20-50%ish throttle I begin to have white smoke pouring out.. under full throttle it’ll clear up to black.. I’m throwing no codes, turbo is rather new and have inspected behind filter and down pipe with no signs of oil.. injectors freshly pop tested, compression test recently has been done. Could injection pump be failing with no codes being thrown? Any other ideas?
