Adrenaline will not initialize
Good day all. Got in my truck one morning and out of the blue my adrenaline tuning variables fail to load. My butt dyno tells me I’m at stock fueling which is odd because I thought the box kept the last loaded tune active. I have updated the app but no luck. Anyone else have this issue? I am running v2.7. Not sure if it’s v2.7.7 but I do have “build date” in data logging. Should I attempt a reflash? Thank you in advance.
Edited by evan717
  • Replies 28
  • Views 9.2k
Thank you! They got back to me yesterday & appears I need to send in for analysis. Thank you all again & will report back with findings.
UPDATE: Just got off the phone with Quadzilla and the Quadzilla passed all tests so signs point to a damaged iQuadBT. Solution is to sell me a new iQuad (Plus). I hate to shell out a quarter of what I paid for it but no other options. Thank you all for the insight.
27 minutes ago, Mopar1973Man said:
The newer head does both the WiFi and Bluetooth both. I've been beta testing on my truck and works really well.
Thank you for the update but still a little sour I've had two major issues within two years. Luckily the first was under warranty.
2 minutes ago, Mopar1973Man said:
Double check your ground too.
Good point!
