- Replies 16
- Views 4.5k
Mopar1973Man 4 posts
Dieselfuture 3 posts
Silverwolf2691 3 posts
EliSweet2202 3 posts
At your boost level, I wouldn't sweat it, unless you get the crazy idea to start trying for 60+ psi. Drive to boost should be 1.2:1 or lower for best efficiency I believe. I think that bec
I would better to change the full turbo and exhaust brake reducing more restriction. Get away from the exhaust brake limitations of the turbos that only fit my set up.
It's too bad this place closed down or at least it says that on line https://www.google.com/search?q=North+American+turbo&oq=North+American+turbo&aqs=chrome..69i57j46i175i199i512j0i512j0
So I have a 01 cummins its pretty much stock other than I have a 62/68/12 with a quadzilla on level 4. I currently have the defueling setting set to 35 pounds because I am on stock bolts but I just learned that drive pressure also affects the head gasket and the ratio needs to be 1:1 correct me if I'm wrong but that's what I've read. How do I figure out what that pressure is at and how do I fix it? In the future I do plan on doing 7x0.12 SAC injectors, DAP valve springs, Hamilton Extreme Duty pushrods, and ARP head studs. Whenever I go to do all this I also want to pull the head and get it surfaced and ringed if ringing is needed.
