I heard a horrible noise when I depressed the brake pedal and then realized the steering and brake power assist were basically nonexistent. After reviewing the situation and knowing the power steering has been getting worse over time I ordered the Gould Vac pump kit and all new lines for p/s pump. I did not pull the trigger on a p/s pump yet because I was hoping to find something more robust or with higher assist compared to my current stock 170k unit. I thought about ordering a Borgeson but then heard some negative reviews regarding installation? Do you guys have any suggestions ? My truck is a daily street /play minimal tow use currently vehicle. I have never been pleased with slow speed steering effort using 31" off road ish rubber. Also if possible I would like to leave my air intake horn on the truck and remove the black intercooler pipe below it only for clearance. In the event the intake horn is coming off (what seems like the 1000th time in 6 months) it would be a good opportunity to look at a banks or ats etc similar intake upgrade. Any thoughts are greatly appreciated.
I put everything back together using a Gould Gear & Electric vacuum pump and Master Pro pump and line replace kit from Geno's . Also flushed system with suggested Napa fluid. I will probably flush
Thanks!
