W-T Ground mod, kinda confused? Quick Help.
- Replies 10
- Views 3.3k
Stanley 5 posts
Dieselfuture 2 posts
Mopar1973Man 1 post
W-T 1 post
Popular Days
Yea I'll search around more tomorrow. For now I just used the stud for wiring harness clamp on vacuum pump. Prolly just a good aye?
He helped me out too good guy
That's what I would have used if I hadn't had a 5mm bolt lying around. The only difference is the diameter of your ring terminal. A ground to the case by bolt or stud is still a ground.
So I'm mid way guess doing this and can understand he group of wires that get spliced into a larger gauge wire, those all get cut and put into a ring terminal at the suggested vp44 ground. Then a ground wire from drivers side battery to same ground spot at vp44 with other wires.
The rest of the wires just go back where they supposed to go...
Now I have the alternator wire that goes straight over to the fuse block. If I'm reading it right I'm supposed to remove it from here then connect back to alternator and route to POS battery on passenger side???
What am I doing with the blank location at the fuse block?
Lastly what am I doing with these grounds just point the one ring terminal back to neg on passenger side battery?
Please let know what I'm missing or not understanding.
