- Replies 18
- Views 2.8k
Mopar1973Man 7 posts
Ravewolf 5 posts
Auto Computer Specialist 3 posts
wil440 2 posts
One thing to remember, just because a sensor is new doesn't mean it's good
Pull the Quadzilla off and reset the error codes and go for a 10 to 15 mile ride and see if the code returns. If the code doesn't return send the Quadzilla in for repair on the boost fooler circuit mo
So I did whap Mopar1973Man said, still no dice. Truck still runs like poop. But thankfully I found a friend who is gonna help me pull my camper. So now my question is, is it the body pcm or the
So I did the wt ground mod on my truck, and also decided to clean up the spaghetti that was on my battery terminals for all my accessories. I wired in two battery bus terminals, and ran all my accessories to them(including the quadzilla module), and ran the power to the positive off the old alternator post on the pdc. Well, that was a mistake because my stupid self didn't crimp the terminal good enough for the wire that runs from the battery positive post to the pdc. It arced inside the connector, and shut the whole truck down. I fixed it right away, but it dumped the programming on my quadzilla. I managed to reflash it, but now it doesn't read the map sensor, and the truck acts like it's in limp mode still. CEL is on too. I pulled the codes, and it gave me a P1693 companion code, and also the usual turbo boost circuit low code. I cleared them but the CEL is still on. Idk what to do right now other than hope and pray it's some stupid fuse I popped, because I have a big trip coming up soon, and I have to pull a camper for 6 hours with this truck. Anyone have any suggestions on what I should do? Thanks in advance.
