- Replies 12
- Views 2.2k
sawdust 4 posts
Doubletrouble 3 posts
Mopar1973Man 2 posts
Royal Squire 2 posts
A little info on the truck would help also. Exactly what year, trans, milage? Maybe put it in the signature line. You will have to check for codes and once it is running look at the live data a
You've done some work on the fuel system, double check everything to make sure it isn't drawing in air. Sounds like it may be loosing prime when it's shut off. Rather than spraying with ether try cyc
Hi Everyone,
I've been lurking on here for a while and I finally ran into an issue that I haven't been able to solve using previous forums.
I put a new crank position sensor in a few months ago after I had the truck not start on me at the dump. I got it going with some spray I know it's not good to do, but I disconnected the power to the grid heater had my wife crank while I squirted into the turbo. The truck ran great for three months or so when it developed a random hiccup.
This brief hesitation is totally random. Last summer I put on a Fass fuel system with a homebrew drawstraw and a Special X VP44 from Blue Chip.
I don't think that this is a fueling issue. I've made sure that all the fittings are tight and there are no holes in the 1/2 line.
last week I was driving home from work when the truck started acting like the crank position sensor was going again: super rough at times and the tach would drop, then right back to normal.
I put in another new crank position sensor two nights ago. ran fine for a day, now runs on spray.
I've checked the voltage from the ecm to the sensor and it's 4.95v.
once the truck is running it runs fine, not like it's running on the cam position sensor. Now there's no check engine light, the truck just needs to get started on the can.
I've been going through the truck and cleaning grounds. my plan for tonight is to do the alternator ground mod from W-T.
Let me know what you guys think
thanks
