New water pump for the RV?
- Replies 5
- Views 2.5k
JAG1 2 posts
Mopar1973Man 1 post
IBMobile 1 post
Threadzy 1 post
Popular Days
Yes, I have. The pressure in the freshwater system is bleeding off. There is a check vale in the pump head that may be leaking pressure back to the potable water tank. The other place pressure can b
Blue and black... You must be color blind...
Mine did the same thing and filled the fresh water tank. Replacing the pump fixed it.
About every half hour my water pump runs for two seconds and I know there are no plumbing leaks in the RV. The water pump is from 2003 and has been let run dry with the switch on accidently for two whole days. Yes, it still works but, is it possible it's letting water back flow to the freshwater side? Anyone ever see this problem?
