- Replies 8
- Views 1.7k
Mopar1973Man 3 posts
wil440 2 posts
matthew gilland 1 post
hdpwipmonkey 1 post
OBDLink LX is great if you don't want a semi-permanent gauge.
The OBDLink is a great little tool to have in your toolbox. You can use it on multiple vehicles to read live data, scan for codes, and reset them. Well worth the price. https://ww
Hello,
I have a late 1999 24 valve sport model appears to be 4 wheel abs, just extra information. Have edge comp, S&B cold air intake, 5 inch turbo back straight pipe, and RV injectors. Rest of truck is stock.
Anyway, I am just curious as to if it is normal for the stock temp gauge on the dash to be at 140*F on a cold engine in the summer. Sits for about a week then drive it off and on this summer 2022, temps reaching high 90*F. But yeah, when I go to use the truck after starting the temp gauge is already reading 140*F. I know that is not normal but I just would like a 2nd opinion. I also do have the Mopar1973Man High Idle/Eco Switch installed. It is switched off the whole time. I even changed the coolant temp sensor right by the t-stat housing.
Is it possible the eco switch has died? Or is there a second temp sensor. It looks like the 12 valve has two sensors but not sure about the 24 valve.
Or is it an ecu failure? I did read something about the gauge cluster is operated by the ecu so that is why I added this option.
Any help would be much appreciated.
Thank you for your time!
