Tried a set of LED headlights
- Replies 10
- Views 3.2k
Mopar1973Man 4 posts
Doubletrouble 2 posts
Hutch24v 2 posts
wil440 1 post
That's the way mine installed as well. Even showed why in the video I think. The led chips need to be in a certain orientation to obtain the proper light dispersion to the reflector. So far I a
Link to bulbs on Amazon. https://linksharing.samsungcloud.com/eSJr7o9DHLbf https://www.nilight.com/products/nilight-9004-hb1-led-headlight-bulbs-70w-14000lm-9004-hi-lo-beam-led-
Nice. I've been thinking about swapping out my regular bulbs to LEDs. I upgraded my truck to the Sport model Quad bulbs. Good to see some cost-effective options here. Thanks! Mark
As the title states, I tried some LED headlights. I did a little research on what kind of LED will work in a housing designed for halogen bulbs. Long story short these are the type of bulb to use.
According to what I read and the videos I watched the placement of the LED chips is important. I bought these bulbs off of Amazon for $39/pair. They're plug and play. Simple as changing a headlight bulb.lol
So far I am happy with the results. I only had the opportunity to drive the truck to work at 3am to test. I believe I need to adjust them down. I didn't get flashed but there were only a few other cars on the road. Pic is a bit fuzzy but you can see how bright they are.
I also tried the high beams and they were definitely aimed to high. I will play with the adjustment when I get a chance.
I am happy with the amount of light they put out, way more than the plain Jane 9004's that were in there. Also gives it a bit more modern look as well. For $39 I feel I got my money's worth.
If anyone is interested in the bulbs or the videos I watched to lead me to this purchase I will post links soon.
