- Replies 12
- Views 1.9k
weissguy01 3 posts
Reaper22 3 posts
hdpwipmonkey 2 posts
Mopar1973Man 1 post
Hey guys,
I just finished a bunch of work on my truck and dealing with some issues I’m not sure are related or not. For background I Pulled engine and trans, resealed engine, new poly motor mounts, new RV275 injectors, new VP and alternator, rebuilt the 47re w Goerend VB and rebuilt transfer case, head studs, resealed AC, rebuilt turbo, new fuel lines, intake and exhaust gaskets, basically went through the whole powertrain.
What’s happening now is I’m not getting a tach signal and the truck sounds like it’s missing at idle and there’s a sharp hiss/tick in the exhaust like a misfire. I’m wondering where the sensor is for the tach signal because I’ve checked all around the motor and can’t find anything not plugged in. I assume it’s the sensor in the back of the timing case between the VP and the block but I’m not positive. I am positive the VP key way is in correctly. Would not having a tach signal cause issues with injector timing or does it sound like I have a mechanical issue inside the head causing this? If the sensor for the tech is correctly plugged in is there a way to test if it’s the sensor itself or an issue in the wiring?
Any advice appreciated as always.
