New IAT, temp goes above 293, watch it drop on the code reader
So the last code I had to deal with was one for the IAT... ordered a replacement and put it in...   The old one looked "melted" https://photos.app.goo.gl/T5s5ek2kwEQnGqBE6 and I discounted because I haven't touched it since 2008....  WHAT would make the temps in the IAT chamber go up so fast?  Burnt valve? I don't have an exhaust brake...
ECM??? would the ECM somehow confuse the interpreted signal? I mean I did watch the temp slowly drop when I turned vehicle off.
Vehicle did get new injectors, it is possible valve clearances got "changed", guy doing the work stated the rockers appeared "loose" but I don't know on which valves.  I don't think this is a new thing, no codes were being thrown BEFORE I had the VP44 issue.
  • Replies 43
  • Views 7.5k
  • Doubletrouble
    Doubletrouble
    I don't know how attached tou are to that truck but just for comparison, $13k would get another running truck in my area.   I've seen them go for less than 9k, might be worth looking fir a donor
  • Tractorman
    Tractorman
    Anytime poor wiring connections are a possibility, the symptoms may or may not be predictable as the resistance value can change at any time for no apparent reason.  The only time an electrical connec
  • Check the intercooler for some type of restriction performance problem.  It may not be sheading heat.
SO... finally got my truck back at the first of August and though I no longer trust the shop, this is what I THINK happened.
VP44 died, was replaced... started throwing codes for the IAT almost immediately....
New VP44 was replaced as a failed rebuild, upgraded the VP44 and ordered injectors and tubes and a new IAT sensor
installed 2nd VP44 with new injectors and tubes, still through IAT codes and melted a 2nd IAT sensor
Sent to a shop.  They found cylinder 5 in some state of disrepair (this is where I loose trust in the shop)  I don't know if the cylinder had a hole in it or what.
(shop ordered the wrong long block first and installed it wondering why truck kept throwing a crank position code)
Shop corrected the long block issue and installed a 2nd new long block, with new injectors and then there was drama with break in oil (they put full synthetic in it for break in and post breakin) never got me the warranty paperwork and eventually I contacted the remanufacture shop, got specific directions on breakin oil and started that process over and ended my relationship with the shop.
Currently breakin with DINO oil is complete, and I have my truck back again (after $14k repair bill).
Ouch. That was painful. At least its repaired and running good!
Yes painful to the extreme, the shop did not help matters ANY... Vette your shops if you are going to trust your truck with them.
