- Replies 19
- Views 2.7k
Tim Waldo 8 posts
Max Tune 5 posts
Mopar1973Man 4 posts
Great work! 1 post
Ya I understand yours is broke off flush. That's why I say you can remove or push back the insulation to give you a little area to slip the tubing over it. By stretching the tubing I got from menards
THANK YOU... that is exactly what I needed. Yeah, prior to this I had a foot long piece of water hose clamped to mine. I am VERY frustrated with the shop because I am SURE it happened on
As you can see, the tube is recessed, I believe it was pushed back while it was in the shop getting the engine replaced...
https://photos.app.goo.gl/xGfBWrPxEVdmixyd9
https://photos.app.goo.gl/KU7x3hpmXF5rNfCP9
https://photos.app.goo.gl/GXqZCPGzihAunuQW6
