6.7L 200 degree thermostat - Experimental Idea
- Replies 11
- Views 3.3k
Mopar1973Man 7 posts
Doubletrouble 2 posts
01_Cummins_4x4 1 post
5akman 1 post
Here it is...
Update... I produced a towing tune and took off for a 5 day camp trip down near Fiddle Creek which is just south of Lucile ID. I can say I hit proper timing in the first try and oil temper
Starting back in the beginning of 2023 winter I opted to play with 200 degree Cummins thermostat from a 6.7L Cummins. Now as winter got to the coldest of minus 7 degrees I was happy to keep a warm cab and engine. I watched over the winter time and as I was able to keep temps above 80 degrees in the intake manifold (IAT) I noticed an improvement in MPGs because cold air does rob the engine of ignition quality and more heat energy is not wasted to the coolant jacket.
Now fast forward to now. I made a trip to Lewiston ID for monthly supplies and food. Still running a 200 degree thermostat in 90 degree weather. This is a Gates Thermostat and seems to hold steady between 200 and 210 degrees of coolant. Even climbing 7% grades everything still running normal specs and no issues. I'm happy to say MPG wise I didn't quite use a 1/4 tank more like 3/16 of a tank in a one way pass from home to Lewiston ID. Level ground EGT's are still cool. Engine oil temperature barely touched 178 degrees even climbing long 7% grades. Boost was between 10 and 13 PSI.
Flat ground cruise
