Is my grid heater dying?
When my truck is plugged in and has sat all weekend, it will fire right up.  I went to leave work today, the wts light ran for a normal amount of time but the truck fired for a second and died.  It did that 3 times, the 4th time it fired up and ran a tad rough for a moment and then smoothed right out.  I figured if I was losing fuel prime it would do that all the time, especially when sitting for extended periods.
  • Replies 24
  • Views 4.4k
  • Using a test lamp, did you check all the places that should have power?  I would do some testing before replacing parts.   - John
  • The battery referenced in the diagram is the driver side battery.   Let us know what you find.   - John
  • Sycostang67
    Sycostang67
    Haven’t gotten to it just yet, the truck still starts which hasn’t helped to light a fire under my butt yet, lol.  I am planning on working on it today though.  Got some friends coming over and we are
That is something I may have to do in the future as well. I've pulled and pushed on the control arms and couldn't get any movement but when someone rides on the passenger side they say they can feel something knocking under their feet when we hit a bump. I can hear anything from the driver's seat. I know the body mount is tight, I've checked that. Only other thing in that area would be the control arm mounts.
3 hours ago, Mace said:
I replaced my control arms a couple years ago with Stryker’s as they’re a tad longer for levelled trucks and the bushings are greaseable.
You can center your wheel by adjusting the drag link by the pitman arm.
I’ve had to do that before but my control arms are so far out of adjustment now that I’ll let the shop handle it.  I had planned to reinstall the adjusters in the same position I removed them from as I marked them beforehand.  After the sawzall, torch and grinder, the marks were lost.  Rotating the alignment bolts also made getting the upper arms back in easier as well.
That sucks. But the truth is just because you can hit the old adjustment doesn't mean it will be the same setting as the old bushings or front-end parts. I tried doing the same for tierod replacement and adjusted to the same length of threads measured but because of small differences, it ate the front tires up in a mere 250-mile trip.
I had scheduled an alignment the week prior.  I get one done anytime I mess with steering parts or anything that could affect the alignment.   The shop I prefer is about 20 miles away so I mainly didn’t want the truck to behave poorly during that time.  I took slower back roads as well, just in case.  No issues though, got it aligned this morning.  Truck is quieter now and takes most bumps a lot smoother.   Just pulling into my driveway is so much better than before.
