Looking for Staff Members
Pulled the truck into the garage to replace some lights. When I tried to start it the WTS light was flashing and the truck would only crank and not fire. I tried pulling codes and got nothing. I disconnected the batteries for a few minutes and nothing changed. I unplugged the Quadzilla and the WTS light functioned as normal. The truck started right up but instantly idled at 1200rpm and then went into 3cyl idle mode. I checked my idle control switch and it’s in the off position. My throttle is also unresponsive(Timbo). Thanks to my low stall converter I was able to get the truck out of the garage and back into its parking spot. When I parked it the idle dropped to 900rpm and still no response from pedal. I assume I need to do an apps reset due to disconnecting the batteries. Could the quad really be the cause of all this? I plan on doing the reset tomorrow and completely unplug the quad just to see if it runs stock.
  • Replies 10
  • Views 498
  • Tractorman
    Tractorman
    Don't have any answers, just waiting to see what the APPS reset offers. It will be interesting to see if the Quadzilla is the culprit. John
  • Sycostang67
    Sycostang67
    I went out and completely disconnected the Quad, and did the apps reset. Truck is back to flashing WTS light even with no Quad and still does the crank no fire. I feel as though I’m looking at an ECM
  • Tractorman
    Tractorman
    I have not experienced your situation, but from what I have read from related past postings on this site, you are in need of a rebuilt ECM. The ECM basically will not boot up, or won't finish booting
  • John
I went out and completely disconnected the Quad, and did the apps reset. Truck is back to flashing WTS light even with no Quad and still does the crank no fire. I feel as though I’m looking at an ECM rebuild? I did check the little bit of live data I get with my scanner and it showed TPS at 93% while not running obviously.
Edited by Sycostang67
I have not experienced your situation, but from what I have read from related past postings on this site, you are in need of a rebuilt ECM. The ECM basically will not boot up, or won't finish booting up, so no engine start.
  • John
Edited by Tractorman
YES, go to the Vendor Directory here on the site and find Auto Computer Specialist. They have a good reputation with good results.
Ok, I found the ACS website and should get the ecm pulled today and hopefully in the mail tomorrow.
Pulled the computer and realized I forgot to get the mileage from the dash. Would it be safe to hook the batteries back up and to get the mileage without the computer installed?
  • 4 weeks later...
Still sitting on my thumbs with the truck. Not totally impressed with ACS, they’ve had my ecm at a work station for 2 weeks with no updates. I finally shot them an email today and was told it should ship out today. I’m going to assume that since I didn’t get an email with a tracking number that it wasn’t shipped. Even if it ships Monday, with the holiday next week I doubt I’ll see it for another week or two. Quadzilla has my tuner, or at least I assume they do. I shipped that to them a week and a half ago and haven’t heard anything from them. I sent them an email 2 days ago and haven’t gotten a response. My truck has been sitting for about a month now and I really have some stuff to do that I can’t do with a mustang.
