Lost coolant - engine got hot
- Replies 20
- Views 3.2k
timsch 8 posts
Mopar1973Man 5 posts
Tractorman 4 posts
Stanley 2 posts
Were you trying to save money on the recycling charge for used coolant? A few years back, I patiently filled my diesel tractor with five gallons of gasoline from a five gallon container. Ya think I
Then fill your radiator 50/50 (water/oil) so the o-ring will stay well lubed! .... just kidding! I do understand that you are trying to make something better. John
If you want to refill coolant properly use a vacuum tool such as Snap-On sells. If your cooling system is in a vacuum coolant will enter every crevice where the vacuum is, hence no air pockets. This
A major short between the ears caused me to lose the majority of my coolant on my drive this morning. I pulled over after seeing mist coming from under the hood. Upper radiator hose was disconnected. My temperature gauge was reading just above the upper line on the sweep but not yet to the red. Engine sounded and performed fine up to me shutting it down.
I added about 2 gallons of water back into the radiator and reconnected the hose and finished the trip without issue. Oil on the dipstick didn't look contaminated. I'm hopeful my engine survived my mistake with no ill effects. Is there anything on it that I should check at this point?
