Any tips on cleaning engine ??? Without pulling it .......*) Cleaning dust etc on TOP*) Cleaning thick oil deposits from previous years of ownership in hard to reach places :cookoo:What works best and whats safe in terms of not damaging electrical ......
  • Replies 29
  • Views 6k
Oven cleaner works well for greasy spots.:thumb1:
Just be aware that if you got loose paint or bare aluminum it will do strange things... The paint it will remove any old paint rather quickly with just a garden hose to rinse. Then as for the bare aluminum is will blacken the aluminum...
Which is really handy on old engines where you want to strip to bare metal.:thumb1:
my miracle cleaner: Here's a semi-before pic. It was actually a LOT dirtier than this. This is after Simple Green.. And here's after KrudKutter (air intake back on, as well)
wow - krud crutter here we come ..........
Krudkuttr on one I just finished a tbelt, steering line and valve cover gasket replacement on. Get kuttr. At Lowes Sent from my HTC Hero CDMA using Tapatalk
Mike, we just went from 70s on Saturday, to 1/2" freezing rain, topped with 4" snow last night..
Get kuttr. At Lowes
Lowes Hey Rogan ... You wiping this on and then h2o off ? Or using as a mix ?
Simple Green is the ticket for maintaing a clean bay. Wont etch your polished stuff either.If you want to get real down to it, take your pressure washer and get the wet sandblasting attachment.instead of sand, run granulated laundry soap through it. Cleanest engine parts and pieces ever..with no fear of residual abrasive since its water soluble :)
