Airdog II 165 install now having problems
- Replies 12
- Views 6.4k
mrtowman4u 4 posts
flagmanruss 3 posts
JOHNFAK 2 posts
jumpjg 1 post
I just installed my airdog 165 fri night and sat I was having problems with it cranking and now it surges going down the road! This morning it took forever to start! When it did crank, drove it to the office and had to keep the idle up and the check engine light came on with the following codes P1692, P1693, an (2) P0122! Any ideas on what to do? I did the fuel module install! Please help!!!
Jason:banghead::banghead::banghead:
I finally got the pressure gauge to hook up an I am running 15 psi! Just as soon as I get it started, it is still loping! I believe I am sucking air some where but I don't know! I took the fuel supply line of the vp44 to see what the fuel looks like coming from the new airdogII 165 and made a video of it!
http-~~-//www.youtube.com/watch?v=A60Z-OORtoU
I need some advice in a bad way!
The airdog I bought has the new push lock connectors on it! Could they be defective and letting it suck air!
Any help is greatly appreciated!!!
Jason
Ok fellas with the help of Michael "Mopar1973Man" an Eric at Vulcan perfomance an a bunch of :banghead: , I finally have my truck up and running!
If anyone needs any help I will do what I can to help!!!
Jason
