ScangaugeII an OBDII
- Replies 27
- Views 8.4k
Mopar1973Man 8 posts
mrtowman4u 6 posts
DieselD24 3 posts
2500ctd 2 posts
I thought I would pass on some info for everyone! I had been talking to Mike "mopar1973man" about adding the scangauge II to my truck, but I am already using the OBDII port to run my Edge Attitude with Juice CTS! Mike an I messaged eachother back and forth, while Mike came up with a feasible idea of hard wiring another OBDII port into the truck, but with unknown an unforseeable issues! I called Scangauge and talked to a lady that was very helpful, explained to her that I needed the OBDII port to run my edge, but I also wanted to run their ScanGaugeII, after a few minutes on hold, she came back with the info on a site that has a "Y" adapter giving you the option of running to ports at once! I ordered the "Y" adapter and the ScanGauge II and will let you know how well it works out! The website she gave me was. http://www.obd2cables.com/products/obd-cables/obd-ii-cables/cable-j1962m-to-2-j1962f-y-cable-1ft.html The cable is very reasonable priced, I ordered my for $13.95 plus FedEx ground for $7.77 so a total of $21.72 I don't believe my nerves could have handled wiring in another port or finding one off a salvage vehicle and then wiring it in would be that cheap! Just thought I would pass this tidbit information on! Jason p.s. Thanks Again Mike "Mopar1973Man":smart:
