Info needed please guys
- Replies 3
- Views 1.8k
Mopar1973Man 1 post
AABEAR 1 post
dripley 1 post
I'm looking at a jacob brake off a 2001 5 spd with the HX35. Wondering if this will fit my 02 6 spd , and also wanted you guys to look at the pics here and tell me if it looks like it's everything here:shrug:. Seller says it doesn't have a switch with it for inside the cab because he's using it for lights now, so wondering if i can just use a normal toggle switch..and if there's anything else that doesn't look like it's there. He said something about a 4 wire mini harness that runs into the cab and connects to the factory harness ? Any ideas on that one. Also, I have the 4" MBRP turbo back which appears to be 3 1/2 " at the flange then expands out right away to the 4 " hooked to my stock turbo , the pic of this doesn't look like alot of room between the flange and the canister on the brake for the pipe to fit on...look normal?
