- Replies 29
- Views 12.5k
Cummins2001 12 posts
dripley 9 posts
Rogan 2 posts
mr.mindless 2 posts
Sceems as if it does it louder when its cold.. Anyways whenever I push the clutch in makes a rattle noise. Asked around and someone told me my throw out bearing could be bad.. Thought Id ask on here see what you all thing... Next is 3rd gear is a pain in the ___ to get into using the clutch.. I can go thro all gears with out the clutch no problem but using the clutch seems as if it hesitates to get in there.. I got the south bend dual disk clutch so i thought maby that could cause it to be harder. Any thought would be appreciated
