A/C leaking into cab
- Replies 8
- Views 4k
5-O Cummins 2 posts
Mopar1973Man 1 post
John T 1 post
MarbleCrusher 1 post
Seems like I got a few problems dropped on me all at once. This time I found that the A/C is leaking back into the cab. I noticed a wet brown colored spot next to the passenger seat and began to investigate. After looking, it seems that the vent tube(?) inside the engine bay is leaking back into the cab. I felt what seemed like a foam oring/seal around the tube in the engine bay and it was soaked. After I pulled the carpet up in the cab I could see that water was coming from the same area inside. Right now I soaked up as much as I could with towels and went and got some damp rid. I figured I would let it dry out for a few days and then try and silicone the tube in the engine bay and then throw some on the inside.I'm sure I'm not the first with this issue so maybe theres a different fix. I'm definitely not taking my whole dash apart though, as long as I dont have to.
