HELP!!!! My tranny wont shift!!
- Replies 8
- Views 3k
dorkweed 3 posts
dripley 3 posts
gassernomore 1 post
AH64ID 1 post
This is for my son,He has an 06 cummins 6 sp tranny. While pulling into to the driveway this afternoon, like a blonde he let his foot off the clutch with his foot on the brake still. the tires kept spinning for about 3 seconds and then it died. Well when he went to start it back up it kinda "lurched" with his foot still in on the clutch and did not want to start. So with the truck turned off he put the stick to neutral put his foot back in on the clutch and then proceeded to start and lo and behold it did. Well now the clutch feels different it will push back up real hard when you have it pushed in and it will not shift in to any gear while running. But if you turn the truck off and have it in gear before turning it on it will start fine, but with your foot in on the clutch it wants to go! Please any thought would be appreciated!
