Replaced my Oil Pressure Sender yesterday...
- Replies 6
- Views 1.8k
AH64ID 3 posts
Rogan 2 posts
98whitelightnin 1 post
That sucked..
My arm is all scratched up from givin' the ol' Cummins the 'reach-around'
At any rate, the old sender was bad; it stayed at 70psi, even with the engine not running..
So dually was kind enough to send me a spare he had (many, many thanks, dually, btw!)
Now, the OP gauge is working properly, and the Edge is now reading oil pressure..
idle, operating temp, is ~55psi, and 2100rpm is 77psi.
184k mi, and due for an oil change..
At any rate, thank you, dually !
