fuel pressure too high
- Replies 15
- Views 10.2k
Mopar1973Man 5 posts
CUMMINSDIESELPWR 4 posts
KATOOM 3 posts
I6FREAK 3 posts
what is the issue with setting fuel pressure to higher levels, 20 or 25 psi so under load it can flow more volume keeping pressure say around 19 psi at wot. also I'veheard that as long as it starts then it is ok....is that the limiting factor of the pressure going into vp44?
