- Replies 16
- Views 3.2k
Pondsy 7 posts
Mopar1973Man 5 posts
CUMMINSDIESELPWR 2 posts
KATOOM 1 post
Folks - I began having issues a few weeks ago and I've done a lot of research on the VP symptoms/diagnosis option to rule the VP in/out as my problem. My mechanic will run the codes with scanner tomorrow when it goes in and replace vp if he agrees, but I'd like to get other opinions as well.Truck has a Fass fuel pump and pressure guage reads 19-21 at idle and no lower than 14 at WOT. Started a week after I bought it. On cold start and go situations, it would not get out of its own way. It would clear up after a few miles and rip like normal.It was recommended that I warm it up for 5-10 minutes before driving when cold out. Wont pretend to know why it was suggested, but I went with it and seemed to be working (or just coincidence) as it didn't happen any more for about a week.Then began to randomly have what I will call "dead pedal". It doesn't matter time of day / outside air temp / or if the truck is cold or up to temp. I will be driving along and driving fine, then I go to accelerate up a hill and it will maintain rpm but wont increase and truck slowly looses speed up the hill. Once over the top of the hill, it will regain, but still won't get up and go like it should.However, that said, sometimes I can let off the throttle for a little bit and get back into it and it will rip again.Codes at this time have only been read with the key trick/not a scanner. PCM is 1693 (not helpful) and 0500 (bald tires lol). ECM is 1693, 0380 and 0216.Anyone have any saving graces or agree its the VP
? Thanks,Bill
