Airdog and fuel pressure
Hey guys, I gots me an AirDog II 165. I installed it back in September and have been with this quirk since then. I'm not sure if it is a problem or anything but just wanted to see if others experience this?I got my fuel pressure at 20psi according to my fuel pressure gauge. When I start the truck and the grid heaters kick on, the fuel gauge will go down to 15-16psi. When the grid heaters switch off, the fuel jumps back up to 20 psi. I have watched the fuel in the line move back and forth to the gauge as they switch on and off.Its a mechanical gauge with a cage protector in between the stock fuel filter housing and gauge.WOT never shows fuel pressure to be lower than 15psi on the gauge.
  • Replies 26
  • Views 7.2k
Ok, so mine is hooked to the batt. I may not be from Missouri but your going to have to shom me. What is the PDC box :neutral:
Here you go... PDC (Power Distribution Center) notice my accessories are tied to the postive battery lead. post-2-138698182408_thumb.jpg Take notice there is isn't any wires hanging off my terminals... post-2-138698182413_thumb.jpg
Does anyone know of any drawbacks in connecting the AD to the alternator?
None... Other that you got more strung around the engine than I do... :whistle:
