- Replies 13
- Views 11.1k
AH64ID 6 posts
blugrasmaniac 4 posts
AABEAR 1 post
Rogan 1 post
I have a 2007 2500 5.9L that currently will not start. If anyone has time to provide some input that would be great!
I have done a lot a reading and basic troubleshooting over the past couple of days, and here's what I know:
[*]Trucked cranked few weeks ago and sputtered for about 3-5 seconds right after cranking. This cleared up on its own after that 3-5 second period, and I did not have any issues while driving it that day or the next.
[*]When I got back to the house, I parked the truck in my yard facing un an incline of maybe 6-8 degrees with ~ 1/4 tank fuel.
[*]It sat parked there for about two weeks before I cranked it again.
[*]After those two weeks, I went out to drive it, and it fired right up. I put it in gear pretty much immediately, and it sputtered out and quickly died.
[*]Hasn't fired fire a lick since then. I did first try adding five gallons of diesel hoping for an easy fix, but that didn't do anything.
Here are the symptoms and facts from troubleshooting so far:
[*]No fuel exiting the CP3 outlet (exception is that once in a while, after not cranking, it will spurt out a small amount right when the engine first starts turning over, and that's it)
[*][EDIT: referring to COV here] Removed the pressure regulator and lots of fuel comes out during cranking
[*]Disconnect the return line and fuel comes out during cranking
[*]Disconnect the feed line, and plenty of fuel pumping into it from the lift pump.
[*]Fuel Control Actuator is open (I can blow/see light through it) when disconnected, and it seems to be working fine. I held it in my hand when key is turned and and for brief cranking cycle - it vibrates enthusiastically, so I assume it's working.
[*][EDIT: I also tried cranking it with the FCA unplugged, but still nothing comes out of the CP3 pump]
[*]I get 8-9 psi during cranking on the fuel line between the filter and the injection pump.
[*]No obd codes (actually I did get a code when I disconnected the FCA, but that went away when I plugged it back in later)
[*]I am still running the SW3 program on the Smart Jr. I keep thinking (and forgetting) to restore the stock program just to see if that makes a difference, but I can't see how it would given the list of symptoms as they currently exist.
At this point, I'm figuring it pretty much has to be the CP3 pump. I don't really understand how it would fail so suddenly and while not in use, but that seems to be the case.
I plan to take the injection pump off next and inspect it to see if there's anything obvious wrong with the gear before I purchase a new one.
I'd really appreciate any input. If you feel it is the CP3, then I could also use some advice on whether it makes sense to replace it with a higher performance pump that would potentially allow for more power in the future.
