- Replies 18
- Views 6.8k
dripley 7 posts
yotehunter 4 posts
CUMMINSDIESELPWR 3 posts
Mopar1973Man 2 posts
First new to site. I have another vp44 question (sorry). I replaced my vp44 back in oct 2011 and also added the raptor frrp pump and i made a big line from fuel filter to vp pump. both were purchased form thoroughbred diesel. At the time i was working out of town and wife was driving it when it did not restarting in the wendys drive through. so i had her tow it to a diesel shop to be looked at. them came back with needing a new vp44 pump. so i order the parts and installed them, got the truck running and drove it 20 miles or so. Got home it sat for 30min and went to start it and it took way longer then normal. So i thought the pump might be making to much pressure so i unplugged the cable to the raptor and the truck fired right up. plugged the cable back in and it hard starts. Crank pressure is 11-12. idle is 16-17 and wot 14-15. so i let the problem go as the truck manly sets and when I do drive it I let it run never turning it off, so today I drove it, turn it off and lets just say she got towed home will not restart. crank psi 12. Not sure but i think the vp44 has gone bad. have no codes. What do you guys think. Thanks for the help.
