Low power CTD issue - KyCTD
- Replies 9
- Views 2.2k
CUMMINSDIESELPWR 3 posts
pepsi71ocean 2 posts
Mopar1973Man 1 post
KyCTD 1 post
Posting this issue for KyCTD since we talked about it in the chat last night and told him I would type it out for him. Bought a 2001 auto CTD that ran fine. One day he started getting on it pretty good and then it just turned into a really doggy truck, slower than any stock truck. Described it as "Geo metro being pushed by a yugo with a 30mph tailwind lol". Found it also had a cracked block. Scrapped the engine and found a 2000 donor truck which was also an auto. Put the engine in using the 2001 ECM and it ran but something wasn't right. Found out the cams were different, switched the cams and that made it run perfect. He used the 2000 VP as well, not the one off the 2001 cracked block. Today or yesterday he was driving along and then it did the same thing. Same slow doggy thing that it was with the other block. It has a new FASS and 18psi idle and WOT. Also has edge comp. Says the edge does nothing, levels 1-5. It has the 1693 companion code which he is finding the other codes out tomorrow and will bring them back to this thread so we can jump into this issue further. Seems like it's in some sort of limp mode, bout all we could figure in the chat room, looking forward to codes. There you have it. I'll let KyCTD take it from here when he gets back tomorrow.
