- Replies 14
- Views 4.7k
Mopar1973Man 6 posts
flagmanruss 3 posts
ISX 3 posts
AH64ID 1 post
I know there is a few of you that might use your RV's through the winter time or just in cold temperatures. Like myself I wanted to keep propane bills low as possible, save water by not having to warm the pipe up again, and just prevent freezing if used in cold temps.So I went down to the local hardware store (C & M Lumber) and picked up several lengths of foam pipe insulation for the RV. You want to look for the insulation that has adhesive on the split part also RV you want 1/2" pipe insulation. It a pretty basic install cut cut to fit, slide the foam over the pipe, pull the cover tape and stick together.Now when it comes to cutting corners it will take some practice of cutting 45* angles and getting them to fit properly.
