- Replies 19
- Views 4.3k
Rogan 7 posts
Cummins2001 6 posts
AH64ID 4 posts
JOHNFAK 2 posts
Ok ive go this new industrial injection turbo silver bullet 66.. I got edge juice hot unlock and ddp 250 hp injectors.. Now wastegate it set at 50 psi. When im towing in 5th gear turbo cuts out sounds like it when you got it spooled high and just let off throttle real quick makes that bark noise. Well it does this while im towing for no reason im trying to pull a hill and it hit bout 25-30psi and it keeps cutting out makes it imposible to pull... Now it only does it in 5th under a big load i can drop to 4th get rpms up to 2500 and it still sceems to cut out a little not as bad as 5th but i can actually get to 40psi in 4th.. Now is this a turbo problem or a fuel problem I thought maby im not getting enough fuel to keep it going at lower rpms but it smokes all the time under a load or not so leads me to think it getting enough fuel.. That and my egt's while not towing are more high then id like running 60mph in a good head wind cant run any lower then 1000 degrees under light throttle chip on lever 3. Makes no sence bought this turbo to keep egt's down and guy i delt thou said it lights at 1200 which it dont really lights at 2000 rpm's but still builds boost up to 10-20 psi at lower but it really dont take off till 2000 rpms. What do you guys think. I was considering getting the silver bullet 64 and see it that helps any maby this turbo just to big.. I dont know any help would be appreciated..
