Help!-Brake Job Gone Wrong
- Replies 45
- Views 7.7k
jamman 14 posts
dripley 12 posts
hex0rz 10 posts
flagmanruss 3 posts
Here is the story:
Front brakes grinding. I know I'm goingto find metal to metal. I open it up and....metal on metal.
I did reading in my manual and postedon a site and found out that with the 4x4 hub and such that thisisn't just as simple as a 2wd set up. I find the trick to use asocket and extension to help ease off the rotor and hub assembly.
I got the axle nut off or rather, loosened(they were easy.I don't know if someone didn't tighten them back up after servicingbefore or what).
But I've got big issues now.
I loosened all the nuts and put thesocket and extension on the top one on the front side. I had the wifeturn the wheel and we did that and kept trying. I loosened it somemore. While pressure is on it I beat on the back side of it. I thinkmaybe it's ready. I have her back off the steering and turn off thetruck. I take out the 4 bolts on the back side as I think I'm aboutto pull the rotor and hub off....
I start to pull and notice, “Hey,that U-joint is coming with this!” So I stop and this is where Iam.
How up a creek am I? I still haven'tfixed the originial problem(get the rotor off and replace with a newone and a new caliper). What the world do I do about this axle shaft?I jacked up that side to try and keep the diff fluid in, but have Ijacked up seals? Am I now going to have to break into my transfercase?
I am a 4x4 neophyte. I've never workedon the actual 4x4 parts before. And of course I'm doing this workwhile broke so I'm trying not to spend anything I don't have to orwouldn't be prudent to go ahead and replace while I'm in there.
So, where am I guys? How do I proceed?
jamman
