Hi folks I am new to the forum. I am a contractor by trade. I can build you just about anything from the ground up. When it comes to vehicles particulary diesel my knowledge is limited. That being said I have a 2005 Ram 2500 and she is acting up. Over the past few weeks from idle to 1500 rpm the truck sputters, vibrates and just runs like crap in general. The truck also acts like the cruise control is set sometimes the throttle won't back down for a good 30 seconds. I will be sitting at a light, motor running at 1500 rpm holding the brake down so she won't take off. I did an oil change, I changed the fuel filter and made sure air filter was good. On a side note and I know this is bad and I take full credit for the stupidity(I should have read the owners manual) that recent fuel filter change was the first one ever and I bought it new:doh:I have run sea foam in the fuel as well as diesel kleen and the problem is not going away.Suggestions, thoughts, has anyone heard of this problem before??
  • Replies 26
  • Views 5k
Any update??? What did they find?
Im guessing injector too. Dont get the 1500 rpm he has to hold the brakes down though.
read more on this, sounds either cracked injector nozzles or they are sticking. either way not cheap. but the common rail injectors are known for problems.
  • 8 months later...
wow really glad I found this site I just bought a 05 to fix up I'm in school for diesel mech so I wanted something to work on seems like a really helpful group here
Silver, I agree..... But lots of times I think it would be a lot smarter if we would not jump right to the most expensive solutions to a problem. I would have suggested changing the filter again to see what's in the tank. Or had him check for air leaks in the fuel system. That's what it sounded like to me. Which could be wrong, of course, but not expensive.Wish he posted back with what the problem was.......:cry:
