- Replies 17
- Views 4.4k
thebullet83 6 posts
KATOOM 4 posts
Mopar1973Man 3 posts
white01 2 posts
i've been noticing things over time, and tried to explain them away.last summer the truck dies not very often when i use the jake and make a shift down to 3rd. did that like three times. then winter comes, and i use the 3cyl idle and the jake, and the truck doesn't stay running. turn the jake off, and egts are only at 200* in 3cyl idle, and the snap of that idle isn't there either, it really only sounds like high idle.last week it died on my 5 times in a day with the jake on and that downshift into 3rd.you guys think it is my vp44? it has 123k on it and i believe it to be original. i've treated it to fuel pressure and 2 stroke oil since i've owned it, but that's only been for about the last 20k miles.
