Getting back into the camper projects...
- Replies 11
- Views 3k
flagmanruss 4 posts
Mopar1973Man 3 posts
dripley 2 posts
AH64ID 1 post
I had torn out the panel under the tub so I could seal around the plumbing to keep the mice out. See earlier post: http://forum.mopar1973man.com/threads/3810-Rodent-Combat!! I wrecked the original panel, a vynal coating on about 2 plys of thin wood on a frame of 3/4 X 3/4 wood. After I finished closing up the plumbing access, I installed wood strips to screw to with the new panel. There is sat waiting for me to get back to it. Yesterday I did (finally) get the panel back in. The top has to tuck under the hook on the tub edge & I had to flex the wall some to get past the corner moulding to the left. I ran a row of screws along the floor into the strip I'd installed. The hard part was the getting the top edge up against the tub hook, I'd anticipated this & put a nylon string around the partto draw it out so my screws could bite. One did, one didn't. I managed to drop down get another screw to bite. I have a piece of quarter round oak that needs finish before I finish screw it along the floor to cover the screws. Then I hung the bathroom door again. I'd had it off to make more room as the plumbing was on both sides of that partition. Working alone was a bit challenging but I used shims to hold the door up. I had designed & installed a magnetic cabinette door catch to hold the bathroom door open... sometimes, depending on how the trailer was sitting, it would decide to close when I didn't want it to & I got tired of hanging up on it. I cut a part of circle of fancy wood which i screwed near the bottom of the door as a door stop, and screwed the magnet to the bottom of that. Once the quarter round is on, the matching steel plate will go back on. Today I went out to work on something else. My dear wifee has been emptying the horse trailer to be sold... by cluttering up the camper. It was just starting to drizzle rain. I discovered the big vent hatch (escape hatch for the top bunk which is gone now) slowly dripping onto the pile of storage stuff. I moved things around to put my big cardboard (kneel on this hunk) on top, & put a container on the drip spot. It'll take clearing the floor & then a step ladder to inspect the hatch. The previous owner had installed a drop down Ikea maple table on the right side under the window. We liked the table but the larger cabinettes above made it hazardous... too easy to stand up under them or walk into them. We had decided to move it to the left next to the stove. I used my squeeze clamps to hold the mounting bracket to the window frame & was able to catch a few screws. It took some finness, but it's now attached to the other side of the trailer. I think the support bracket needs a repair but I can just remove the hinges on that & drill / screw it back together. In the meantime, I had been laying out some discount store roll up bamboo blinds for rear windows. It was a tight fit, because of the cabinettes above. In the end, I screwed the left side to the wall under the cabinettes. The right side had different cabinettes & I screwed up into the bottom of them. I had to fold the triangular mounting tabs over horrizontal & screw right through to get them high enough. The trick to getting this done was I used my pair of squeeze clamps... to the window track on the front side & opened the window & clamped the trailer side in the rear... to make a support to hold the blind's weight while I worked. Because the blinds are over the top part of the windows... I'm only using 2' of an 8' blind... there rolled up blind cluts the window area. I'm thinking about super glueing a row across & then cutting them off & moving the groved bottom stick up. I marked across one blind & did the super glue. I left it for the day. I'll check it in the future & see if it took before cutting. (Might not be able to get another exact blind from the Job Lot closeout store... And I don't want to end up with a bunch of kindling!) There were some & I had installed more screw eyes & folding tie anchors in the walls to secure cargo. These changes may require more or moving them. So this is my weekend's worth of progress.
